AIO Pump noise won’t go away
Solved by Badger24,
I just got a Corsair H115I Platinum 280mm cpu cooler used from a friend. The temps are good and it runs well but the pump is extremely noisy. Turning the pc on its side makes it go away but when I turn it upright again it comes back. Is there any way to get it to go away completely?
EDIT: I forgot to plug in the usb cable that controls the pump speed lol
EzioWar ·
Posted in Operating Systems1 -
4
1
Pryme ·
Posted in Power Supplies8 -
EzioWar ·
Posted in CPUs, Motherboards, and Memory1 -
4
WallacEngineering ·
Posted in PC Gaming0 -
Astrophel ·
Posted in Storage Devices1
