Looking for advice on case airflow
By
HA_VE
in Cases and Mods
in Cases and Mods
Solved by Votivee,
Why don't you just buy a new cooler for your GPU? Something like this: https://www.arctic.de/en/ax3
Since that case has a mesh front I'm going to say it already has good airflow. I wouldn't pay the premium and switch to noctua fans unless you're looking for silence. I'm sure your fans move enough air as it is.
kim921 ·
Posted in Build Logs1 -
Dalynx ·
Posted in Storage Devices0 -
Fat Cat11997 ·
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
