help editing my parts list
Budget (including currency): 600 USD
Country: US
Games, programs or workloads that it will be used for: the highest workload this thing'll endure is just cause 3 at low settings.
Case      48.49
https://www.amazon.com/Cooler-Master-Transparent-Adjustable-Ventilated/dp/B0785GRMPG/ref=sr_1_15_sspa?dchild=1&keywords=matx+pc+case&qid=1618532532&sr=8-15-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFJRkxTODhWNjk4WFgmZW5jcnlwdGVkSWQ9QTA5MDA2NTcyTDAwTUk2NzVES1FJJmVuY3J5cHRlZEFkSWQ9QTAzNTI1MzkzN0FZMjlUWTlWVTNMJndpZGdldE5hbWU9c3BfbXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
Motherboard     77.99
https://www.amazon.com/Ryzen-Gaming-Motherboard-B450M-CSM/dp/B07FKV5HWJ/ref=sr_1_8?dchild=1&keywords=motherboard+AM4+socket&qid=1614386363&s=electronics&sr=1-8
CPU 119.99
https://www.adorama.com/amdy325fhbox.html?gclid=CjwKCAiAkJKCBhAyEiwAKQBCkuZmcCEMZW43aMhBiRC0pqWzPwZZDYnGQFGGF5eCWufk9W-i-DxAwhoCd0wQAvD_BwE&gclid=CjwKCAiAkJKCBhAyEiwAKQBCkuZmcCEMZW43aMhBiRC0pqWzPwZZDYnGQFGGF5eCWufk9W-i-DxAwhoCd0wQAvD_BwE&utm_source=adl-gbase-p
RAM    32.95
https://www.amazon.com/Yongxinsheng-240-pin-1600MHz%EF%BC%88PC3-12800-Memory-Desktop/dp/B07ZRGD1F9/ref=sr_1_7_sspa?dchild=1&keywords=8gb+ram+kit&qid=1614394168&sr=8-7-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyS1Y3TFg4NjlRTVk3JmVuY3J5cHRlZElkPUExMDEzNjc4UDZDUFRLMTdLUUpCJmVuY3J5cHRlZEFkSWQ9QTA0Njg4NzIyOUdFRzdaUzRGSUlYJndpZGdldE5hbWU9c3BfbXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
HDD         54.99
https://www.amazon.com/Seagate-BarraCuda-Internal-Drive-3-5-Inch/dp/B07H2RR55Q/ref=sr_1_3?dchild=1&keywords=2tb+hard+drive&qid=1614321024&sr=8-3
Cooling       8.89
https://www.amazon.com/Cooler-Master-SickleFlow-Computer-Radiator/dp/B086HLNPJT/ref=sr_1_17?dchild=1&keywords=pc%2Bfans&qid=1613966481&s=electronics&sr=1-17&th=1
PSU      38.99
Amazon.com: EVGA 100-N1-0400-L1 , 400 N1, 400W, 2 Year Warranty, Power Supply 100-N1-0400-L1: Electronics
Monitor      99.99
Amazon.com: HP Pavilion 22cwa 21.5-Inch Full HD 1080p IPS LED Monitor, Tilt, VGA and HDMI (T4Q59AA) - Black: Electronics
OS     25.75
https://www.google.com/shopping/product/9055827571864254764?q=operating+system&rlz=1C1CHBF_enUS837US837&sxsrf=ALeKk00NMj7_SKU1zl2yot5xswja_3R1Xg:1613601566521&biw=1366&bih=695&prds=eto:9460194980824833496_0&sa=X&ved=0ahUKEwjSo7qj_vHuAhVCs54KHe9xCU8Q8wII_wU
Keyboard    19.99
https://www.amazon.com/PICTEK-Architecture-Independent-Anti-ghosting-Splash-Proof/dp/B07XDHLJ9M/ref=sr_1_15?dchild=1&keywords=gaming+keyboard&qid=1613601669&sr=8-15
CPU cooler 19.99
https://www.amazon.com/Cooler-Master-Addressable-Anodized-Aluminum/dp/B081W9NRLG/ref=sr_1_6?dchild=1&keywords=cpu+cooler+am4&qid=1615144446&refinements=p_36%3A1253503011&rnid=386442011&s=electronics&sr=1-6
Mousepad 13.99
https://www.amazon.com/VicTsing-31-5%C3%9715-75In-Extended-Stitched-Water-Resistant/dp/B0794WBPHK/ref=sr_1_11?dchild=1&keywords=desktop%2Bcomputer%2Bpad&qid=1615111084&sr=8-11&th=1
Speaker 17.99
https://www.amazon.com/AmazonBasics-Computer-Speakers-Desktop-USB-Powered/dp/B07D7TV5J3/ref=sr_1_16?dchild=1&keywords=computer%2Bspeaker&qid=1615111835&s=electronics&sr=1-16&th=1
first of all you need ddr4 ram.  You have listed here ddr3.  I would recommend at bare minimum 8gb but 16gb if you can spare it.  Ryzen prefers fast ram as well so the faster you can get the better.  Your CPU already comes with a CPU cooler so there is no need to get a different one especially when on such a tight budget.  Get a ssd, drop the hdd to a 1tb and get a 250gb ssd.  Trust me you will thank me later.  And finally, try and get a bit better of a psu.  Im not saying that its bad but you really should try and get one with at least a bronze rating.  Make these changes and you should be good to go.  Best of luck!
Current Rig=  AMD Ryzen 9 5900x, Asus Crosshair Hero VIII, EVGA RTX 3070 FTW3 ultra, 32gb Corsair Vengence Pro RGB 3000hz White, EVGA 750 P2 PSU, 1TB Samsung 980 Pro, 500gb samsung 860 evo, 250GB Samsung 850 evo, 2TB Samsung 970 Evo Plus, 2TB seagate firecuda sshd,  LianLi PC 011 Dynamic XL ROG edition, Corsair h150i elite capelix
I suggest using PCPartPicker.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Have a look at this instead
kept the CPU and adjusted the motherboard and ram. Also added an SSD for very fast general use (trust me, don't boot windows off a hard drive)
You can use the same mousepad, keyboard, speaker etc. But you should cut the CPU cooler out of the budget for now.
Primary PC:
