Need help about slot spacing on Rog crosshair VIII dark hero
Solved by KnotRolls,
You certainly can put dual 3090s on a ROG Crosshair VIII, that said why do you want this beyond a mad flex on expensive parts?
Definitely make sure you get a super beefy power supply to handle this though. You'll also want to make sure you're using a Ryzen 3000 or 4000 (Non G-Series!) spec CPU so that you're running at PCIe 4.0.
ROG Manual: E17453_ROG_CROSSHAIR_VIII_DARK_HERO_UM_V2_WEB.pdf (asus.com)
