HELP PLEASE 1st ever build
Solved by Fasauceome,
1 minute ago, Max L said:how many fans will one argb header be able to handle a argb spliter?
5 or 6 fans can easily be run off one header, at least. The fans appear to have a standard 3 pin daisy-chain design to them, should work just fine.
Jojo0607 ·
Posted in Peripherals2 -
1
Siper_ ·
Posted in Graphics Cards1 -
ShadeBorderlands ·
Posted in Programs, Apps and Websites1 -
1
Champs ·
Posted in Troubleshooting3
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
