High-pich sound from PSU when moving mouse
Solved by FRD,
Yep, it is coilwhine. Usually you can't really fix it, some people RMA it and get it replaced.
Also, I'm sorry but the PSU you chose is not a good one. The rest of your parts are good, but the PSU is in Tier E according to the list here.
If possible try to send it back and get a better one. Now I would not recommend upgrading or using a good GPU in combination with this PSU.
