Which PSU plugs for 8+4 pin CPU power?
Solved by Analog,
5 minutes ago, chudtopia said:not a complete expert but i think you should be able to put it in the other cpu pin slot and it should only fit on one side
The connectors are keyed, you can't really mess it up. The 6+2 pins and the 4+4 EPS connectors all can be connected to the same spots and are 8 pins. The peripheral and SATA are 6 pins. 24 pin motherboard connector - self explanatory. This is how they are divided:
