ULTIMATE RGB PC Build Guide 2021
James
Buy Intel Core i9 10850K CPU (PAID LINK): https://geni.us/JuTllC
Buy ASUS ROG Strix RX 6800 GPU (PAID LINK): https://geni.us/5nGt
Buy ASUS ROG Thor 1200w RGB PSU (PAID LINK): https://geni.us/23RR0L
Buy G.Skill Trident Z RGB 4x16GB RAM (PAID LINK): https://geni.us/r2clEbq
Buy MSI MAG Coreliquid 360R CPU Cooler (PAID LINK): https://geni.us/ee3mj
Buy Phanteks p500a Digital (PAID LINK): https://geni.us/NFeG
Buy Phanteks Neon Digital ARGB LED Strip Combo (PAID LINK): https://geni.us/PtVhJ5
Buy Phanteks Neon Digital ARGB LED Strip M5 (PAID LINK): https://geni.us/hWksyCH
Buy Cooler Master ARGB GPU Support Bracket (PAID LINK): https://geni.us/I0NkhjZ
Buy Cooler Master ARGB LED Controller (PAID LINK): https://geni.us/rvHhx
Buy Cooler Master ARGB 1-3 RGB Splitter Cable (PAID LINK): https://geni.us/F3JV90
Buy ARCTIC BioniX P120 A-RGB Fan (PAID LINK): https://geni.us/QqM2Z
Buy Corsair iCUE LT100 Smart Lighting Towers Starter Kit (PAID LINK): https://geni.us/6eCRz
Buy Corsair ST100 RGB Premium Headset Stand (PAID LINK): https://geni.us/1U0nu
Buy Corsair Virtuoso RGB Wireless High-Fidelity Gaming Headset (PAID LINK): https://geni.us/Ta74q
Buy Corsair MM700 RGB Extended Mouse Pad (PAID LINK): https://geni.us/6BAvkj
Check out the Marsback M1 Keyboard at https://lmg.gg/zXgDr
Check out the Zephyr Gaming Mouse at https://lmg.gg/l0aI7
We're at it again, this time using no internal proprietary Corsair parts and relying entirely on ARGB headers for the update to our 2017 RGB Build Guide
Because RGB is Really Great Booosssstt!!!!
remember, the rgb gets you a 40 fps boost
R gives you more FPS
G gives you more NVidia points which makes your raytracing go faster
B gives you more cooling to make your components go faster
elephants
Recently dealing with the ASUS Thor PSU. Asus recommends to not have the fan facing up when there is no venting from the case. The paid link shows a different model as the one linked doesnt have a viewing section for the PSU. Watching the video at 10:57 you can see there is no ventilation from the PSU chamber and the main area of the case. Since this is a 1 off build and not to be used as a daily driver it should be ok but I would note that anytime you put a heavy restriction on a PSU that it could cause issues. If someone where to use a smaller Thor PSU the fan would most likely turn on since you would be utilizing alot more power from the PSU thus it would need more airflow. Since you are using a 1200W PSU for the video this problem could be mostly averted. Note that this is different from the fan normally facing up as that is ok its the issue where its being placed with the fan pointing towards a surface that doesnt have perforation holes thus restricting its ability to get any air.
Just thought I would note this down since the exact reason is why I chose another PSU and a case that doesnt have a PSU view. I wanted to use the 850W Thor but use a small case and none has available airflow where even ASUS was saying they do not recommend it as it could cause overheating restricting the fans access to air.
**I could be wrong as the case could have the holes but I do not see any ventilation**
Time to binge another video lol.
edit instead of double post:
Used to be said that it gave you aimbot skills from cod games, good times 2010.
edit2: Seeing anothiny drop something at 1:07 made me laugh out loud, good one ❤️
Useful threads: PSU Tier List | Motherboard Tier List | Graphics Card Cooling Tier List ❤️
Baby: MPG X570 GAMING PLUS | AMD Ryzen 9 5900x /w PBO | Corsair H150i Pro RGB | ASRock RX 7900 XTX Phantom Gaming OC (3020Mhz & 2650Memory) | Corsair Vengeance RGB PRO 32GB DDR4 (4x8GB) 3600 MHz | Corsair RM1000x |  WD_BLACK SN850 | WD_BLACK SN750 | Samsung EVO 850 | Kingston A400 |  PNY CS900 | Lian Li O11 Dynamic White | Display(s): Samsung Oddesy G7, ASUS TUF GAMING VG27AQZ 27" & MSI G274F
I also drive a volvo as one does being norwegian haha, a volvo v70 d3 from 2016.
Reliability was a key thing and its my second car, working pretty well for its 6 years age xD
@GabenJrYou asked us to ask you how you know the USB 3 connector breaks.
How do you know the USB 3 Connector breaks?
Record holder for Firestrike, Firestrike Extreme and Firestrike Ultra for his hardware
Top 100 for TimeSpy and Top 25 for Timespy Extreme
Intel i7 10700 || 64GB Kingston Predator RGB || Asus H470i Strix || MSI RX 6700XT Merc X2 OC || Corsair MP600 500GB ||  WD Blue SN550 1TB || 500GB Samsung 860 EVO || EVGA 550 GM || EK-Classic 115X aRGB CPU block - Corsair XR5 240mm RAD - Alphacool GPU Block - DarkSide 240mm external rad || Lian Li Q58 || 2x Cooler Master ARGB 120MM + 2x Noctua  Redux 1700RPM 120MM
Ahhh... now i know how much they get for an ad paragraph.
Will you make a mix of the ROG pc and the RGB pc so you get THE ULTIMATE ROG RGB PC
Note: Building a computer at this time is a bad use for your stimulus check(not just the OP PSU), period. Old stock typically full retail, new stock is basically non-existent.
I've never had one break, and I've done some stupid stuff to mine 😂
Just wanted to appreciate how Anthony dropped the solution to my RGB problems on a sidenote (JackNet RGB Sync works great), I immediatly had to spend a couple of hours fixing my PC ^.^
The Phanteks neon stripes look amazing imo, but they don't really stick in my experience (at least not for long), I'd recommend using real glue if you intend to keep your system with the strips for a while..
Anyways great, entertaining video with some takeaways 🙂
1 hour ago, JOHNNYTHEWOODBOY said:
I also did a build in the P500A. How did I do?IMG_20201201_201238.thumb.jpg.b61c510c6467f74b6657428044b8aaa2.jpg
Nice build, the nvidia adaptercable is unfortunate though 😅 have you tried routing the gpu power on top of the hpu backplate behind de aio tubes(maybe rotate the aio 180° horizontally) so the tubes hide the adapter and the front part looks less empty.
No, I think I might get a custom cable that terminates to 12 pins directly.
That's a fine solution too, nothing to add then 👍
(I mean as by the video, there's always rgb to add 😅)
Anthony seems kind of awkward and distracted in this video, like he's having to do a PC build at gunpoint.
System Specs: Second-class potato, slightly mouldy
He probably spent the whole shoot internally screaming "all that money could have gone into better parts instead of shiny lights!"
  • 4 weeks later...
The bionix fans are too thick for any radiator screws, how did Anthony manage to screw them in with the provided screws?
  • 5 months later...
Came across this video after being recomended the one about mixing ram since I want to add another 8 or 16, and think it'd be hella dope of they were RGB.
Pretty good. A small thing though. The keyboard doesn't exist. it's not available. Also Razer is well known for their RGB, everything.  I love the huntsmen, and this ruberdomeone who's name im having a late night brainfart on. Fantastic fealing keyobards for joe average. Also you get RGB mice! I have a pictek fast to the point of stupidity mouse with RGB
and even rgb game controller.
Also! that man needs a raise!
Weird. seemed like he was doing fine.
