First PC Build for Medium Level Gaming Advice? - $1300US
Solved by Frugivore8894,
7 hours ago, York18 said:Yea I've got about $420 to spare but I wanted to know if I should save this until I can buy a new, better GPU or if I could buy other components that would enable me to play high end games like RDII or CB77
I would say you need to upgrade that cpu or downgrade the MB. It’s a bit off balance but I would not spend too much on thoughts things. I would do what you got (upgraded cpu) and save up for a better card in the future. When I say upgrade I would just do a 3600x or 5600 if you can find it.
