Search In
  • More options...
Find results that contain...
Find results in...
please recommend a reliable and with top of the line hardware for the money (840 $) size 45 inch
Size?
Use case?
I must be out of the loop, because when did top of the line tv tuners cost more than $80 ? I've 4 or 5 pci hd dvbt tuner cards around here somewhere.
What makes them so expensive now?
Silent build - You know your pc is too loud when the deaf complain. Windows 98 gaming build, smells like beige
5 hours ago, Enderman said:
Size?
Use case?
45 inch and movie watching and gaming
That's a very rare size.
Many more options around 40-42" or the next step up is 48-50"
55" is about the most common option so sometimes its actually cheaper to buy that instead of a smaller size, depending on the model.
I would recommend you take a look at rtings.com, they have the most in-depth objective and scientific reviews of TVs.
the problem Is I cant make up my mind to what to buy this my frist big to buy so can't mess it up !! please help
Look for something with low latency and good colours.
A few years ago I bought a 55" NU7100 series from Samsung, 4k 60Hz.
Now you can find stuff better though.
Newegg
