Does Resizable Bar Work with Intel CPU and AMD Card?
Solved by xenosys,
It does, provided your motherboard provider has an BIOS update that will allow you to enable it.
I have a 9900KF and 6800XT with a Gigabyte Z390 Master and they kindly provided a BIOS update a few weeks ago.
Noticed some performance improvement in games like AC: Valhalla (from 65 to 71 FPS on 4K Max Settings) and Gears of War 5 (85 to 91 FPS on 4K Ultra Settings). You won't see an improvement in a lot of games, and the odd game may actually be worse by a frame or two, but hopefully game developers will take advantage of ReBAR in future.
