Pop/Click sound when clicking on any Forum link.
Solved by colonel_mortis,
The forum opens an audio context when the page loads, to use for notification sounds, and I suspect the sound is being caused by something in the audio stack switching on to handle that. It only happens if you're logged in, which will be why you didn't encounter it on the Aida64 forums. You can turn off notification sounds in https://linustechtips.com/notifications/options/ if you want, which should solve it.
