Help please not a dream build
Solved by FakeKGB,
Just now, MechWill said:pcpartpicker has a glitch that says the motherboard is not compatible. All x570 motherboards are compatible with ryzen 5000.
They are, but some require a BIOS update.
The motherboard OP has chosen has BIOS flashback capability, though, meaning that OP does not need a Zen 2 CPU to flash a BIOS onto it.
