Search In
  • More options...
Find results that contain...
Find results in...
Need Help Tweaking PC Part Picker Build
Currently own a 1060 6gb that I plan to upgrade to a 3060 TI once prices settle. Have all the Storage already. Mainly trying to find a nice case that has good airflow for the future 3060 ti. Not very enthusiastic about the Corsair 275R look.
Budget (including currency): Trying to keep this upgrade below 700$
Country: US
Games, programs or workloads that it will be used for: Most demanding game will probably be Hunt Showdown.
Build looks good. Mediocre airflow probably wont kill you with a 1060 or a 3060 so if I were you I would go with the Corsair iCUE 4000X RGB.
My Future Build [Specs]:
Intel Core i5-10600KF
Nvidia GeForce RTX 3060 [Waiting for Restock]
Nvidia GeForce GTX 680 [Currently in my build]
AsRock Z490M-iTX
Team T-FORCE DARK Za 16GB @ 3600MHz
Corsair MX500 1TB SATA SSD
WD Blue WX81D 6TB @  5400RPM
My Future Build [Cooling, Case & PSU]:
NZXT Kraken X53 RGB [AIO CPU Cooler]
NZXT H210i Mini-iTX Tower Case
Seasonic FOCUS PX-750
My Current Build [Peripherals]:
Redragon K552 RGB [Outemu Blue Switches] [Black]
Razar Viper Mini [Black]
Viotek GN24CW 24-Inch @ 1080p 144hz [FreeSync Disabled] [White]
overkill, id rather just get some 4000d case
Does the standard version of the 4000D have much worse airflow relatively to the airflow variant? Or is that something i shouldnt even be too worried about in my build
airflow is way better, it has excellant airflow, not airflow is doo doo
Do you need a wifi card or are you going to use ethernet only?
Thats a good point. I am planning on being Ethernet exclusively, but i dont think a wifi card/ dongle could hurt
