Reviving a dead battery pack
On 4/6/2021 at 9:21 PM, badreg said:the product was sitting on the shelf for too long
If a battery like that has discharged that much, there's more going on than it sitting on a shelf long.
On 4/6/2021 at 9:21 PM, badreg said:Is the voltage too low to be revived?
Yes, I think so. I once tried to revive a 2.0V LiPo cell and it didn't work out, the damage was already done. In your case, you're at 0.43V, good luck with that. You can give it a shot, but don't expect much from it.
On 4/6/2021 at 9:21 PM, badreg said:ould I be able to parallel charge with a working pack without disassembling the pack?
In theory you could but you need to keep in mind three things:
- do this outside
- use a power resistor in between the batteries to limit the current! Do not connect them in parallel directly.1
- you can't be sure about the balancing of the cells, so unless the pack has a balance lead, or you are able to open it up, it's guesswork what the cell voltages are.
1 Li-ion cells have a very low internal resistance. Connecting a lower voltage cell to a higher voltage cell in parallel would therefore cause huge amounts of current. For instance, if I try to charge a 3.5V cell using a 3.6V cell, I get an effective voltage of 3.6-3.5=0.1V. That may not seem much, but if the cell has a 0.001 ohm resistance (which is not unrealistic) you'd get 0.1/0.001 = 100A of current (!). You're at 0.43V, so you'd have a voltage of say 3.7-0.4=3.3V (across some tiny resistance). So you'd be generating an insane current through an already damaged cell. A recipe for disaster. This is why you need to add a resistor to limit the current (or use a proper charger, but I assume proper chargers refuse to charge that pack haha)
