Search In
  • More options...
Find results that contain...
Find results in...
Announcing new combined topic for F@H. Official LTT F@H FAQ & Guide.
Gtx 1070 core not boosting & doing only 22Mh/s with mem overclock
Hey, need help with something, so i bought a gtx 1070 to swap it for my rx 480 i am a miner and my rx480 mines just fine but sucks at games and i slow in windows, so i got my gtx 1070 today installed the drivers and ran my miner as a benchmark and started overclocking with MSI Afterburner... First i noteced that in HW monitor it hasnt a power consumtion sensor, than i noticed that i cant control the power limit, when i do it crashes like the system has a 10second delay on all movement, than i played around with the memory (before 21Mh/s) the overclock went well but nearly did nothing to my Mh/s (+1Mh/s) witch was really weird im using Phoenix miner btw. (tried NBminer same resault) but than the main issue: my frequency doesnt move after it reaches 1582MHz after running the miner if i change it in Afterburner nothing, if i add voltage nothing, if i edit the voltage/frequency curve nothing, i also did a bios mod using NV flash but the card i am using (PALIT dual) isnt listed on Techpowerup bios list so... i flashed some VBIOS  with the same version a mine was showing at Gpu-Z, if anyone knows how to fix the frequency or the Hashrate beeing low/stuck at one place, please let me know
First thing I'd try, is DDU on the nvidia driver. All Nvidia GPU's (10 series and up), have the ability to display power consumption. This is only missing if the driver has crashed at some point. For example,
Current Build
  • 2 weeks later...
already did that like twice didnt help 😞
Try underclocking the memory and see if that helps. Ideally in GPU-Z you want the memory controller load as high as you can get it.
Pascal has a hardware related issue when it comes to mining ETH that Nvidia has acknowledged in the past and cannot be fixed.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | Storage: 250 GB Crucial BX100 SSD + 2 TB Seagate HDD + 1TB WD Green + 3TB WD Red | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9360 | CPU: i5 7200U | RAM: 8 GB
Newegg
