Good monitor for M1 Mac mini
Solved by Slottr,
For what this system is, you won't be getting 4k 144hz out of any games you'll be playing.
If you want a 4k display- you need to up your budget to at least 250-300$. That will not be a high refresh rate display either.
You might want to look into the M1 chip a little more before pulling the trigger. I don't think you're quite up to speed with what it is/can handle
BTSHalfLifeAndGmodFan2003 ·
Posted in Graphics Cards0 -
4
john b ·
Posted in Phones and Tablets3
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
