How do I tell if my AIO is working properly?
10 minutes ago, Krosis said:Hi all,
I recently switched to a NZXT X53 after using air cooling all my life (mostly due to pet hair issues).
I am usually idling between 35-43C on my Ryzen 5 3600 (with PBO). On a Prime 95 small FFTs test for maximum heat, my max CPU temp is 78C.
This would indicate that my AIO is doing it's job properly. However, my issue is that the NZXT CAM software is telling me that the liquid temp in the AIO doesn't go higher than 35C during this stress test.
Also, with a Deepcool Gammax GT air cool, I used to idle around 30C.
How is that an AIO is worse than a $45 air cooler?
I have 2 Deepcool 120 intake fans in the front, one exhaust in the back. NZXT X53 240mm rad exhausting up top.
I am aware my current setup has basically become negative pressure, as opposed to positive pressure with my air cooler. Could this be enough reason?
Assessing idling temps are difficult without measuring the power usage in each scenario, I'd look more into the maximum temperature as that's more consistent to measure and having a loop temperature of 35C sounds about right, it shouldn't be as hot as your CPU as then it would be worthless as there's no temperature difference.
I can't tell you if the AIO is working optimally or properly but it's definitely working, if not then you'd thermal throttle instantly.
Comparing a 240mm AIO with a single-tower aircooler should be similar in performance, I think..
