Search In
  • More options...
Find results that contain...
Find results in...
Palit join in the 6gb vram bandwagon for their 780
brownninja97
 Share
In a nutshell this is the standard 780 jetstream but with 6gb vram, i guess its nice because this cooler is better then EVGAs, might not look the best but its quieter and it cools better.
I hope this is a thread that everyone adopts.
http://www.techpowerup.com/199226/palit-readies-geforce-gtx-780-jetstream-with-6-gb-memory.html
Listen if you care.
Why.... It's so useless... 1 780, let alone 2-3 don't have enough GPU horsepower to fill 6gb :/
Not to fully use it, no, but they do have enough to push past 3GB. Really though, for extremely high resolutions, 780s aren't quite enough.
Anything past 3gb will be sub 60 FPS, when I get near the 3gb mark I'm hovering from 50-70 depending on what's going on the scene (tons of animations I get around 50, scenery mostly I get 70~ and that was overclocked to 1280 mhz + 7300 on the mem.
There's a guy on overclock.net that has 4 titans that did 7680x1440 benchmarks+game FPS averages, even with QUAD TITANS he was only getting ~50-65 fps at 4.5gb of vram.
 So double 780's will struggle to even do 3.5gb I'd imagine.
So its a GTX titan (non black)? What difference does it have, besides the cooler.
Case Bitfenix Ghost, Mobo Asus Maximus VIII Ranger, CPU i7 6700K @4.2 Ghz cooled by Arctic cooling Freezer i30, (barely). GPU Nvidia GTX 970 Gigabyte G1 @1519Mhz core, RAM 16Gb Crucial Ballistix CL16 @2400Mhz. SSD 128GB Sandisk Ultra Plus as my OS drive. HDD's  1TB  Seagate ST31000524AS its OEM, 3TB Seagate Barracuda, 2x 500GB WDC Blue (RAID 0)
If it isn't working absolutely perfectly, according to all your assumptions, it is broken.
Double precision floating point, just means it's better for rendering/content creation. You can basically OC a 780 past a titan anyways
WHY?
ヽ༼ຈل͜ຈ༽ノ raise your dongers ヽ༼ຈل͜ຈ༽ノ
It feels as though no games ever leave the BETA stage anymore, until about 3 years after it officially releases. - Shd0w2 2014
WHY?
well its bottlenecked my 3gb vram, its not going to use 6gb but the extra space should help
Listen if you care.
Let us not forget multimonitor work, not just games
Keep your opinions out of news posts, not only is it unbecoming but you're also wrong like 95% of the time.
In case the moderators do not ban me as requested, this is a notice that I have left and am not coming back.
i fucking like the cooler, from past experience everyone else hates it and i dont know why, also i will keep putting my opinion, sorry thats just my thing, you cant take that away from me unless you are a mod which you arent
Listen if you care.
 Share
