Search In
  • More options...
Find results that contain...
Find results in...
which is better and by how much?
giorgi1997
 Share
The R7 265 is more powerful by about 10-15%, but it also costs more and consumes much more power while creating a bit more heat.
Main Rig: CPU: AMD Ryzen 7 5800X | RAM: 32GB (2x16GB) KLEVV CRAS XR RGB DDR4-3600 | Motherboard: Gigabyte B550 AORUS ELITE | Storage: 1TB Samsung 970 EVO Plus, 2TB ADATA SX8200 Pro (SM2262EN), 512GB SKHynix PC401 | GPU: EVGA RTX 3080 FTW3 ULTRA HYBRID | Cooling: EK-AIO Elite 360 D-RGB | Case: Corsair 5000D Airflow (White) | PSU: Seasonic Focus GM-850
Server: CPU: AMD Ryzen 5 3600X | RAM: 16GB (2x8GB) G.Skill Ripjaws V DDR4-3200 | Motherboard: ASUS ROG Strix B550-F Gaming | Storage: 512GB SKHynix PC401 NVMe, 4TB Seagate IronWolf, 128GB Samsung NVMe, 1.2TB ioDrive2 PCIe SSD | GPU: MSI GeForce 210 | Cooling: AMD Wraith Spire | Case: NZXT H500 (Black) | PSU: NZXT C 750W (Gold)
Tribute: CPU: AMD Phenom II X4 840 | RAM: 8GB (2x4GB) Kingston HyperX Genesis DDR3-1600 | Motherboard: eMachines DA061L-3D | Storage: 256GB Crucial MX100, 1TB Toshiba X300 | GPU: EVGA 8400 GS 1GB | Cooling: Stock | Case: eMachines EL1352 | PSU: Delta 220W
They're about the same, but the 265 is slightly more powerful. I would go for the 750Ti, just because at the moment, AMD and all of their prices are driver issues are bullshit, whereas Nvidia doesn't have that problem. What will you use your system for?
I budget build well. Want to learn? PM me if you want advice.
mostly gamig
750Ti without a single doubt.
AMD's driver support is already a reason to not buy the 265.
crysis3_1920_1080.giffarcry3_1920_1080.gifbf4_1920_1080.gifac4_1920_1080.gifbf3_1920_1080.gifbatman_ao_1920_1080.gif
Source: TechPowerUp
The 750 Ti is slower overall, but I would go for it, considering it has 60W TDP and the AMD card has 150W TDP. You could also overclock the 750 Ti much more than the R7 265.
My PC: CPU: Intel Core i3 3220, MB: ASUS P8P67 LE, GPU: Palit Jetstream GTX 670, RAM: 4GB 1333mhz DDR3, Storage: 750GB Hitachi, PSU: CoolerMaster G650M 80+ Bronze, Cooling: Coolermaster Hyper 212 Plus, Case: Multirama, Display: Acer x229w 22" 1680x1050, Keyboard: Logitech K120, Mouse: Steelseries Kinzu v2, Sound: Logitech 2.1 system
Source: TechPowerUp
On average when gaming, the R7-265 used only 30w higher than 750Ti. A normal light bulb use more than 30w.
R7-265 is basically a HD7850. HD7850 is a well known overclocking monster, most people can easily overclock this pass 1100mhz.
Almost on par with R9-270x.
I would say 30W is still not a small difference. Plus the 750 Ti is cheaper. But I guess if the OP wants the absolute best in that class he should get the 270. I would say that's a far better choice than the 265. It all depends on much he wants to pay. The cards are priced according to their performance.
Depend on how much cheaper the 750 Ti for TS, at my country the 750 Ti is only $10-$15 cheaper compare to R7-265.
30w of electricity is small, people often overlook it like leaving the light or keep the TV on. Unless the electricity is uber expensive from where TS live, i'll still recommend 265 over 750ti.
 Share
