Why doesn´t the Master Cooler software work?
Solved by Adrian12,
1 minute ago, lukke pukke said:HI!
I have recently build mt first pc an i got the Master Cooler MB311l as the case. I plugged the led cables in to my chassi and they change to orange color. I downloaded the software but it just says that no compatible devices was found. I didn´t get the ARGB controller so I´m asking you for help.
The case: https://www.coolermaster.com/catalog/cases/mini-tower/masterbox-mb311l-argb/
The software: https://coolermaster.egnyte.com/dl/4rjcDCJRVw/?
The software will probably be from your motherboard manufacture
