Max Safe Temp for ddr3 ram?
Go to solution Solved by Guest,
Yes. Its fine.
i oced my ram and its hot as my gpu when idle if not then lower, my gpu is 45c when idle so is it safe for my ram to get as hot as 45c?
Yes. Its fine.
