How to restore and keep files
da na
Is there a way to restore windows but keep all of my files and programs? I accidentally screwed up a registry and need to reset Windows because my computer will not turn off. I have a reinstall disk, should I use that, or will that replace my programs and etc.
You could take your SSD/HDD out of your computer, hook it on to a different one and copy all your Data and for example saved gaves in order to back them up. This won't work for your installed programs though.
Quote or tag me( @SEAL62 ) if you want me to see your reply
consider a reaction if I was funny, informative, helpful, or agreeable
OS: Windows 10 Pro
CPU: Intel i9-9900K GPU: Aorus GeForce RTX 3080 Master Motherboard: Gigabyte Z390 Aorus Master
AIO: Corsair H150i RGB Platinum RAM: Corsair Vengeance RGB Pro 32GB 3000MHz Case: Corsair iCUE 465X RGB PSU: Corsair RM750x White
OS: Kali Linux
HP Envy x360 Convertible
CPU: Intel i5-10210U GPU: NVIDIA GeForce MX250 RAM: 16 GB DDR4 2666 SSD: 512GB PCIe
