Oculus Rift S - Worth it, or not?
bellabichon
Hi all,
Now that I have a rig that can actually handle the games, I've been looking into PCVR, specifically the Oculus Rift S. I'd like to try out Beat Saber, Half-Life: Alyx, Skyrim VR, and a bunch more. My price range is around $500 CAD, so it seems the most reasonable option for me (it's also $100 off on Amazon Canada right now, which is nice). From Linus's review and others, it seems the on-headset tracking is nearly as good as lighthouse, and the ease of setup is a big plus for me.
So, are there any Oculus Rift S owners (or prospective owners) willing to weigh in? I understand that the display resolution and refresh rate aren't the best, but the features seem unbeatable for the price.
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
if you ignore the facebook controversy, its basically fantastic. but because of the FB issue, I would steer away personally and wait for more headsets to become cheaper.
From my breif experience with HTC and with oculus, the HTC headset is far better, but the oculus controllers are literally the best (ignoring valve index because price). So I would go with oculus only if FB change their policies (or if you are willing to mod the oculus to de-facebook it).
While the Rift S works nativly with PC, Oculus have shown a clear 'you are the favourite child' preference to Quest / Quest 2. Supposedly getting a 120Hz option soonTM, alongside having a larger resolution would have me seriously considering a Quest 2.
- A Rift CV1 owner
Edit: There Is also a new Vive headset on the way (rumoured to be a Quest 2 competitor), but nobody has any idea how far off that is.
Edited by Cela1
- A Rift CV1 owner
Hmm. Feels weird to be paying for all that extra hardware when all I'm really going to use is the PC functionality, but the higher resolution and refresh rate are certainly tempting. Do you know if I would be able to connect the Quest 2 to my PC? It seems like the only option is a USB-C cable, and my GPU doesn't have a USB-C port (and the one on my motherboard is finnicky as all hell).
Main PC:
Peripherals/Other:
Unless you are buying from a retailer (which is perfectly ok), the base Quest 2 should be the same price as the Rift S.
Oculus Link doesn't use the port on your graphics card, it uses a standard USB-C port ( or potentially USB-A with connector).
However, if you have doubts about Link, or only have USB-A ports, then I would probably just stear clear of the Quest lineup then.
Yes, you can connect the Quest 2 to your PC and play full-blown PCVR. You don't have to (nor do I think you can) plug into your GPU though. And while the official Oculus link cable is USB-C to USB-C, you can also buy a third-party USB-C to USB-A cable, as long as it's rated for USB 3.0 with 5 Gbps transfer speed. And you'll need an open USB 3.0 port on your motherboard as well of course.
I've personally really enjoyed using my Quest 2. It's nice having the flexibility to play PCVR or break free of the cables and play native games on the headset itself. And if you have good upload speeds on your PC, you can even stream the games wirelessly through the remote desktop app (costs $20, so around the same as a third-party link cable).
I mostly speak from my own past experience from similar problems. My solution may not work for you, but I'll always try my best to help as much as I can. If you want me to see your reply, make sure to quote my comment or mention me @WaggishOhio383, and I'll get back to you as soon as possible.
-- My PC Build --
Ryzen 7 2700x
AsRock B450 Steel Legend
XFX RX 590 Fatboy
Crucial Ballistix Tactical Tracer RGB 16GB 3200MHz
120GB Crucial BX500 SSD + 2TB Seagate Barracuda HDD
Corsair CX650M
Phanteks Eclipse P350x
Yup. My controller rankings would go:  Vive < WMR < Oculus < Index
I've used all major VR headsets since the first rift hit the market (bar Pimax / Vive Pro) and the Rift S is still my favorite all rounder for the price.
The only real challenger is the Quest 2, but even then you will definitely need a better headstrap and the link cable (if you have slow wifi and can't use virtual desktop) which adds to the price. I did actually buy a quest 2 (again) last week, as decided to get one to use as a standalone for fitness. Using the two side by side for PCVR, I actually prefer the picture on the Rift S (with SS). Mostly because there is a bit of artifacting and noticable input lag on the Quest 2 and that's with 500Mb broadband in my office where I play. It's noticable even with the link cable however if you're a first time buyer, it's unlikely you will notice it. Playing games wirelessly is amazing though. It's tough to decide between the two as to which is a better recommendation for PCVR for a first timer. I would say Rift S but could understand if people think Quest 2 is the better option.
Sorry that doesn't help much but, If your question is whether or not the Rift S is worth it for the price, then I'd ssay 100% yes. I would also highly recommend getting Viveport as well. It's essentially Netflix for VR games. There are hundreds of Oculus games on there and loads that are well worth playing (Westworld, Paper Beast, Pixel Ripped, The Room, The Wizards, I expect you to die, Superhot VR, Arizona Sunshine, Moss and loads of others).
