Annoying Sound Coming From PC
venomx
Does sound like a fan problem to me. Check your front mounted fans for dust, close cables or other things that might interfer with them.
Quote or tag me( @SEAL62 ) if you want me to see your reply
consider a reaction if I was funny, informative, helpful, or agreeable
OS: Windows 10 Pro
CPU: Intel i9-9900K GPU: Aorus GeForce RTX 3080 Master Motherboard: Gigabyte Z390 Aorus Master
AIO: Corsair H150i RGB Platinum RAM: Corsair Vengeance RGB Pro 32GB 3000MHz Case: Corsair iCUE 465X RGB PSU: Corsair RM750x White
OS: Kali Linux
HP Envy x360 Convertible
CPU: Intel i5-10210U GPU: NVIDIA GeForce MX250 RAM: 16 GB DDR4 2666 SSD: 512GB PCIe
I  took the front panel off, then back on - seems to have stopped now. I'll keep an eye on it
Stopped for 5 mins now its back
Definitively the fans, fix the fans with something like this
Yeah I have the same buzzing, its the front fans. In my case they're screwed in pretty tight yet sometimes they buzz. Will get to sorting it out when im not lazy.
most fans come with a rubber bushing on them that is supposed to go between the fan and the bracket it is attached to which would stop any rattling of the fans.
