Top fan for intake or exhaust
Maruf Hussain
Hello guys i have a Gamemax H-605-WT Mid Tower Gaming Casing which have 2 top fan and 1 back fan. Well its a common sense that back fan is for exhaust but what should i do with top 2 fans should i put it for intake or exhaust for my system cooling. Btw i have i5-9400f and a gigabyte gtx 1660 super in my system
i usually do exhaust for the tops. you can always switch them if it isn't cooling well.
I also usually do top exhaust, but I prefer slight positive pressure, so if you only have 3 fans I would recommend using 2 as intake and 1 as outtake
Tough to say as it looks like there is only a grille under the psu, the top mesh and the rear exhaust grille.  However, the 9400 shouldn't have a problem with temps if you're changing the air either way.
-> Moved to Cooling
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
