No post situation with Ryzen 5000.
Feger
I’ve recently bought a MSI MPG X570 GAMING EGDE WIFI and Ryzen 5 5600x combo. It didn’t post. Does anybody have an idea as to why it doesn’t work? I’m sure that i’ve connected everything right ( i’ve done this before ).
Did you update the BIOS?
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
Does your motherboard box say UPDATED FOR / COMPATIBLE WITH RYZEN 5000 SERIES anywhere?
Not yet. I’ll try it though.
Nope
Nope
Yep that is most likely the issue. Update it
Desktop :
Laptop :
Alright. I’ll update you if it anything happens.
I fought all night but got it working. A huge thanks to everyone who helped me. I’m really grateful.
  • 4 weeks later...
MSI seems to have major issues with 5000 series. I had the same issue and just switched to my ASUS board and booted instantly. Others have messed around with jumping the CLR_CMOS. I'm glad you got it working but you should look up Hardware Unboxed's video about MSI board VRMs. That board has one of the worst VRM setups and cooling. Seems like MSI opted for better VRM on their mid-range for some reason.
