What is best for GeForce experience a.k.a. NVIDIA Container ?
Solved by Archer42,
2 hours ago, Yohelpmedogimlost said:So the bitrate is set to 50Mbps, but I also watch these videos and the playback also uses bandwith.
Which is what, 6.25MB/s? That's so low that absolutely any hdd manufactured within last couple of decades will be easily able to write it, and with buffering writing/reading at the same time will not be an issue either.
2 hours ago, Yohelpmedogimlost said:I thinks a WD40EFRX would do the job
Be careful, modern wd red drives (would be WD40EFAX) are SMR and should be avoided. Will probably still be able to handle it, but depending on situation SMR drives can be incredibly slow.
