I need help!!! Screen not displaying anything.
Hi
As the title says, my screen doesn't show anything while my PC is on. To give a bit of context, last night my PC got a BSoD, so I waited for it to shut down and went to sleep, this morning I went to turn it on to do my job and the PC started normally, the lights were on and the fans were spinning but the screen doesn't display anything. Since I'm using an HDMI to VGA adapter, this was normal, unplugging and plugging it again usually works, but not this time, the screen turns on but it just black, it detects the PC since it doesn't show the 'device not detected, check cable connection' text, the mouse and keyboard's lights are also on but when pressing the CAPS button I don't hear the beep. My specs are: Motherboard:MSI A320M-A Pro
Graphic Card: GTX 1650.             CPU: Ryzen 6 2600.                              And 16GB of RAM.                              Would be glad to get suggestions on what to do. Thanks in advanceiv widget.
*Ignore the spoiler mark, I don't know how to delete it.
