Real VNC viewer launchoption shortcut to open remote in one click?
Mr.Stork
Every time I want to open my raspberry pi, I have to go through this screen. And when I open the pi, this window stays behind the entire time unless I close it. It unnecerally adds adds extra clicks. Thankfully it doesnt ask for pass or username as I've saved them.
I was thinking, some lines could be addede to the "Target:" at the end of "....exe" in a shortcut properties on desktop? I'm not sure about the launch commands to make my pi open in one go. Help is appritieated.
Thanks.
image.thumb.png.dd8fc514b9220ab974b54280c8d8d815.pngimage.png.65051f46a0dad8b2c9e7ab64b8ed992c.png
https://archive.realvnc.com/products/vnc/documentation/4.2/win/winvncviewer.pdf
Contains instructions to auto connect using shortcuts, batch files & from command line. The guide is a little outdated but should still work.
Main Rig:-
Server:-
Unfortunately, it doesn't. They removed the option to "Load/Save" option. I also tried using the command line, but it doesnt work as well...
