Can i use the m.2 from a Pcie Wifi card, and slot it into a wifi m.2 slot.
Solved by Fasauceome,
11 minutes ago, Zakk8 said:could I put a wifi m.2 into any m.2 slot or does it have to be a specific wifi m.2 slot?
M.2 WiFi doesn't fit in the same slots as M.2 SSDs. It does need to be a WiFi M.2 slot.
11 minutes ago, Zakk8 said:I have a motherboard that has a wifi m.2 slot. I see that on my pcie wifi card it literally just has a wifi m.2. Can i simply unscrew it from the card and put it in the motherboard
should work
