Why is my PC taking so long to boot? pls help
Solved by RAS_3885,
1 minute ago, Woag said:Hey so I just finished working with the RAM and nothing really changed but I found out the buzzing was coming from one of my HDD so that might also be where the problem lies
A buzzing HDD is certainly not good and might be causing the issues. Not sure why your motherboard would have the RAM debug lights on, but if playing around with the RAM didn't help then certainly try unplugging the suspect HDD.
