Fan for NH-D15
jm_bmw
Hi everyone,
The original 140mm fans doesn't fit the case, so I replaced with a 3pin 120mm one, just one in the middle. Temps are ok in games (60-70C) but if I stress the CPU it will easily reach 88-93C. Fan curve is already tuned + undervolt.
I am looking to replace with a better 120mm PWM fan, and here comes the first question, will it matter/worth at all?
If yes, filtered down to these 3 models that are available here:
-Akasa Viper
-BQ Silent Wings 3 High-Speed
-Scythe Kaze Flex RGB 1800rpm
Also not sure about flow vs pressure design for this heatsink...
13700 . B760 . 32GB 6000C32 . 1TB+2TB M2 Gen4 . RTX 3080 . 55Q80A 4K@120Hz
You do realize what the words "stress test" mean right?  If a stress test doesn't push your chip to throttle, your cooling is more than adequate.
Your temps in gaming are good as well.
You're overthinking this.  Your cooling is fine.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
What I would recommend is the included Noctua fan. Can you clarify exactly why that wouldn't work?
6 minutes ago, jm_bmw said:
the original 140mm fans doesn't fit the case
Cannot fit due to tall RAM heat spreaders (RGB probably)  and case won't allow for clearance.
You should be able to fit the 140mm in the middle of the two towers though. I'd just pick up a NF-A12x25 for the second fan if you're that worried about temperatures.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
My bad I didn't explain it well. Right now it stays like this due 24C ambient, but in hot days like 30-34C here it will thermal throttle in stress tests and games that use more cpu (like ACO) will reach 85C in some cores. I thinking that a higher RPM fan will help.
Yes, the case side panel doesn't close, the fan stays mm's higher than the heatpipes and due being a glass I can't flex it.
Are you sure the cooler is mounted with the correct pressure? Nocuta's mounting system is arguably the best for air coolers, but I'd expect the D15 to do better than that. Unless the 9900 is an extraordinarily hot chip. IDK...
I'd put in another vote for the NF-A12x25 fans as @SpiderMan suggested. They are awesome. A bit pricey, but awesome.
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
If you really want to replace it just get an arctic p12 fan. Noctua performance super low price.
The problem with NF-A12x25 is that it is available in just one store down here and costs 3-3.5x more than the ones I mentioned. I mean... I would rather add more ram for this amount of money.
@RAS, yes it is mounted fine, hot days really change things up...
@Jaslion, it seems like arctic's CFM is lower than the deepcool I am using... how acurate those companies numbers vs marketing are IDK...
You could always try one of noctuas p12 or f12. And if you really can't do those there's always corsairs ml120 though it's ungodly loud.
