Beyerdynamic DT990 Pro not loud enough
Solved by GuiltySpark_,
3 minutes ago, finster2702 said:Ah I see I'm using the bus powered ones so maybe I'm missing out on the extra 50 ohms. If I plug the device into a USB3.0 port will that give them more power?
I'm not actually sure now what they mean, I'm not familiar with the device so I had to look it up. When that FAQ says "mains power" that means the wall. Like, using a normal wall power cable. Looking at the back of a Scarlet 2i2, it doesn't have a normal power plug. Maybe they sell a USB wall adapter that gives it enough juice?
