Having problems with running Doom Eternal
Solved by NelizMastr,
The GPU usage is too low. While the 380X is already not much of a powerhouse these days (still beats buying a new one lmao) D:E really isn't light enough to get such low usage.
Try reinstalling the AMD driver. Uninstall using DDU first.
xo33 ·
1
Linkinworm ·
Mortal_2077 ·
Posted in Graphics Cards1 -
7
2
5
TPhill110 ·
Mozametweakin ·
Posted in New Builds and Planning1 -
8
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
