low fps in valorant?? pls im so confused
desgustting
Hi everyone, so i installed my new rogstrix geforce rtx 3060 into my pc and before i had an amd 570x. I currently have an amd 5 2600. In valorant on all low settings I am ranging 100-215 fps. Should i be getting a lot more fps saying i am running on all low settings. pls im so confused and when i had the 570 installed i was getting 70-150 fps.
If you are playing on a 1080p screen with all low settings you are most likely getting CPU bottlenecked.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
How can I fix this? Would I need to overclock my cpu or buy a new one entirely?
If you don't have a high-refresh rate screen, why would you need to have the game run with hundreds of FPS?
To answer your question, I doubt that overclocking will make that much of a difference. I mean you will certainly see a performance bump, but probably not as much as you wish. You probably will need to upgrade your processor to something that has significantly more power. What motherboard do you have?
-> Moved to PC Gaming
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
First question, did you delete radeon drivers when installing your new card? If not download DDU: https://www.wagnardsoft.com/forums/viewtopic.php?f=5&t=3450
Run and reinstall nvidia drivers.
Go to Nvidia control panel : Tab Program settings ->Fortnite
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Noctua NH-D15 with one fan
FS in Denmark/EU:
Asus Dual GTX 1060 3GB. Used maximum 4 months total. Looks like new. Card never opened. Give me a price.
i have a 144hz msi monitor and i wanted the fps due to streaming it drops my fps quite a bit. i have a b450f motherboard.
I did that earlier today but not sure if i did it right,
You should be able to drop in a 5600X in that motherboard with an appropriate BIOS update if you decide to upgrade the processor. You will get a considerable performance bump with it, as it will not bottleneck your card as hard at 1080p low settings.
This is with a RTX 3070, which is more powerful, but you get the point.
honestly with this gen of gpus, at 1080p, if you're playing at low settings you're doing something wrong... higher settings would take load from the cpu to the gpu, which is preferable in my opinion, and *might* even get you better fps, however 200 sounds a lot already and with a 144hz monitor you don't need more than that anyway.
I would suggest to bump settings to medium / high and maybe try locking the fps to your monitors refresh rate, which is an option in most games nowadays.
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
