Power button won't start the system (shuts it down ok tho)
Solved by Hyrogenes,
10 minutes ago, Absentidei said:It is.
When I configure windows to put the computer to sleep when the power button is pressed, it does, and it wakes it up again.It also powers down the system when pressed and held down for ten seconds.
It just won't start the computer from power off.
How are you turning it on now? Are you manually shorting the pins?
