Black Screen Crash, Audio still works, fans loud
Solved by Pixelfie,
Another AMD user with crashes... there are so many people on 21.2.x or 20.11.x with pc's getting random reboots/black screens/lag spikes. What I recommend is dowloading DDU, loading safe mode and uninstall the drivers using DDU. Download 20.12.1, install that, disable updates in the AMD software, and it will be a lot more stable. I've had this myself with my 5500 XT and a lot of my friends & some people on this forum seem to have simular issues. I recommend reporting this bug to AMD so they can fix it.
