PSU coil whine
Solved by SupaKomputa,
coil whine is a normal problem doesn't effect performance or durability.
no your gpu got nothing to do with it.
if you still have the warranty, i can ask for replacement.
Tydn12 ·
Posted in New Builds and Planning2 -
2
ID0 ·
Posted in Networking2 -
eviohh ·
Posted in Troubleshooting3 -
5
IhateAMDDRIVERS ·
Posted in Troubleshooting7 -
SashaSanguine ·
Posted in General Discussion6
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
