OLED Monitor?
JBurlison
Hi all,
I am looking for a HDR monitor, one with a great picture! Price is not a concern and I also have a 3090 with a 10900k so I can pretty much drive whatever monitor I want. There's so many I don't know what one has the best picture quality. Prefer ultrawide as I do work on it. I do game but play more casual games like some light wow, Minecraft, Valheim, PoE. I beat the story of most AAA games that come out for PC too. I'm not too concerned with getting 300 hz on it but I def want over 60. Top of the line picture quality is what I'm really aiming for here. Any suggestions?
EDIT:
I did have the Odyssey G9 from best buy but had to return it as there was flickering and the top few alternating rows of pixels where dim. The colors looked very off too.
There would be some LTT videos on this.
Oled not great, unless you want to burn money.
Good for visuals though. Heard a lot of issues with ultrawide screens and about the G9 not being the best quality which is a shame.
HDR is a different story, for gaming. Don't think it will be good for ultra wide in a while, as in power consumed and being heavy to level of brightness levels that you would need.
There are a few OLED monitors. Most of them are in the 50-60" range or ~20" though
From what I could tell they're not the best for pc monitors mainly due to burn in and limited sizes/refresh rates
Here's a decent list of OLEDs available
Could always just use a TV like the LG CX 48"
I feel like a TV would be too big for in front of me. Any suggestions for non oled with high hdr ratings and good black levels?
The only true monitor I like is my LG 38" 3840 X 1600 IPS monitor.
The reason I like it is that unlike my 3440 X 1440 monitor it stands up well against 4k in text quality and it has enough vertical height so it does not feel like looking through a slit.
A 3840 X 1600 monitor is a lot harder to run than a 3440 X 1440 monitor and frames in games are closer to 4k so I would not recommend one for anyone that does not have a 2080 ti or better.
I also use TVs as monitors.
LG 55" OLEDs for gaming and a 49" NanoCell for general computing. All have HDMI 2.1 and are 120hz at 4k with a 30 series card.
The OLEDs are great but they are not a single monitor solution.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
IF u get a 48" (or upcoming 42") OLED TV u can, if u so choose, run it at 3840 x 1440 or some other vertical resolution below 2160, for an ultrawide experience.
I often run my 42" plasma in ultrawide, granted I have to go the extra step of using DSR due to it being a 1080p display, but it works well for ultrawide none the less.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
  • 1 month later...
yeah I am eyeing out the new odyssey g9 myself looks like amazing product, the new display could solve all the issues that are with the current model. Hopefully will not introduce new
AMD Ryzen5 5600X   -   Asus TUF x570-Pro (Wi-Fi)   -   G.Skill Trident Z RGB 32 GB DDR4-3200 CL14   -   EVGA GeForce RTX 3080 Ti 12 GB FTW3 ULTRA GAMING
be quite! Dark Rock Pro 4  -  be quiet! Pure Base 500DX   -   Samsung 980 Pro 250 GB, Samsung 970 Evo 1 TB   -   SeaSonic Focus PX 850W 80+ Platinum
Logitech G413 Carbon   -   Logitech G502   -   Logitech G533
5 hours ago, Piecku said:
What you want does sadly not exist unless you get a tv 😞
The monitor market is just that bad yes
well miniLED is coming out, and they will have in the range of 1400 nits of brightness?
Although have to see about the quality range for adjusting brightness and details and if it will be long before ultrawide MiniLED.
This year it seems like the miniLEDs are coming out, might be as expensive or more than OLED, they might be set to be in higher resolution (4K) but unsure.
