X58 Xeon build questions
Soj
Go to solution Solved by Herman Mcpootis,
normal ram is fine.
Hi guys this is my first post here!
So I have a gigabyte x58a ud3r rev2 motherboard with i7 950 and 3x2 gigabytes of RAM
I also have a R9 390.
I snooped around online and found out I can upgrade my computer without spending too much money and so I went ahead and bought A Xeon 5675 processor on AliExpress .
I have some experience in computer building though it was back when Pentiums reigned supreme so it’s been a while.
So the processor itself cost around 20 bucks and my question is can this Xeon work with normal ram or do I have to get ecc?
if I do need ecc will my mother board support it?
Is there an Overclocking guide video online that deals with the exact motherboard that I have?
(haven’t found one).
Regarding the ram size: since my motherboard supports 24 GB of RAM and triple channel I guess my best option is go with three sticks of 8 GB though I cannot seem to find it anywhere and would love a recommendation on where to get this kit.
thanks!
normal ram is fine.
  • 1 month later...
thanks!
Hi, i have a same platform too and wondering if I can do the same upgrade.
So, how is your system now? Did the XEON work smoothly?
System
  • CPU
    Ryzen 5 3600
  • Motherboard
    Asus TUF GAMING b450M plus II
  • RAM
    32gb 3200Mhz Hyperx RGB
  • GPU
    Zotac Gaming GTX 1660 TI
  • Case
    SilverStone FARA R1
  • Storage
    256gb SAMSUNG 970 Evo Plus m.2 NVME SSD + 2tb HDD
  • PSU
    EVGA 500 BR
  • Display(s)
    24'' AOC 144hz IPS Panel
  • Cooling
    DEEPCOOL GTE V2
  • Keyboard
    CHERRY G80 3000
  • Mouse
    HYPERX Pulsefire FPS PRO
  • Sound
    SADA 2.1 Speakers
  • Operating System
    Windows 10 Professional
  • Laptop
    ACER Nitro 5 i5 8300H + GTX 1650
don't to xeon cpu's as they are for workstaions and basicly not that big difference in gaming  between core i series cpu and xeon , but when it comes to overclocking the core i series are the best.
