Merge Xbox and PC Audio Out into controller
1 minute ago, TheCoder2019 said:
I want my voice to go to my Xbox, have my Xbox audio come out, have my PC audio come out and inject PC audio in my Xbox party if this makes sense
You could maybe do this with some breakout cables - you'd need a pretty complicated setup.
Literally the only way to get the PC Audio going into your Mic feed (I'm assuming so you can play stuff and your party can hear it), is to take your PC Audio Out, have that go into a Mixer, have your Mic also go into the same mixer, then output the Mixer to the correct cable, which goes into the Mic port on your Controller. I'm assuming you have the controller with the 3.5mm port btw.
In terms of the Audio from the Xbox, you have two ways of doing that, and it really depends on how the Xbox handles voice chat. You can either take the audio out from the back of the Xbox (optical or whatever - I don't recall if there are RCA jacks for audio), convert them to the correct cable type (Eg: if optical, use optical to RCA converter), then jack that cable into the Mixer (That way the mixer is outputting both the Xbox audio, and the PC Audio into your headphones, as well as into your Mic).
Alternatively, you might have to use a 3.5mm breakout cable to separate the Output and Input from the controller, routing the Output to the mixer, and the mixer into the Input.
No matter what, this is gonna be cable city, with cables going everywhere.
