PC Shut Down mid-game and fails to power on
Solved by MNiyazi,
8 hours ago, Bloodline01 said:I just finished the paperclip test and the fan of the PSU did turn on. I kept a SATA cable in the PSU that had powered on my LEDs and fans and they all turned on. Unfortunately this led to a new problem (I don't know if its directly a PSU problem or me making a dumb mistake). The cables that plugged directly into the motherboard on their respective header from my CPU cooler fans and fan hub started to have a really bad burning smell. After I turned off the PSU and took the cables out, the side the plugs into the motherboard continues to have a noticeable burning smell. No other cables have the smell.
If the mobo have burning smell I would RMA it
