Search In
  • More options...
Find results that contain...
Find results in...
Need help, m.2 slot wifi card doesnt fit on m.2 slot
Go to solution Solved by Bombastinator,
All m.2 is not created equal.  M.2 and pcie are not the same.  M.2 has a “key” system.  Nvme is m key and sata is B key for example.  My memory is wifi is a different letter entirely.  Those slots in the end of the card are the keys.  They’re designed so a card has to have the right slots to fit.  Often motherboards have slots for wifi cards, but they’re in an entirely different place and are not long like that.  Often they point straight up.
Need some help with this.
Its my first build i do, and im having a problem with the m.2 slots.
I have a asrock b450m pro4 motherboard, wich has two m.2 slots (one normal and other one ultra) and i a bought a intel ax200 wifi card wich is m.2, but for some fucking reason the little card its off by 2mm or 1mm in the m.2 slots of the motherboard, and i dont why the fuck is like that. I asked my dad (he's a electronics guy) and told me that the card has a conection thats not making contact with the conector and because of that the intel card has the 2mm or 1mm diference thats not letting it go in the m.2. So idk what the fuck is going on and thats why im making this post in hope that someone can help me with these. Here are some pictures of the mess.
10 minutes ago, bmx6454 said:
it's m.2 2230, which slot 2 can fit, but slot 1 can't. https://www.asrock.com/mb/AMD/B450m Pro4/#Specification
edit: could be wrong, but i thought that mobo's that could accommodate m.2 wifi had a specific spot for just wifi cards. either way, slot 2 claims it will fit 2230.
I already tried put in it on the other m.2 slot and it also has the same problem
the wifi card slot's afaik are m.2 key e, which the two on your mobo aren't.
So that means i bought something completely wrong?
Fuck, then i think a bought something completely different. Well thanks for the help
Maybe.  Your motherboard manual could be a help here.  You might have a third m.2 slot that is e key, but is not listed with the other two but as a slot specifically for a wifi adaptor.  Many monos have this.  Quite frequently if there is also a wifi version of the board.  Sometimes whether a board is the wifi version is just a question of if the slot is populated at the factory or not.  Generally in these situations the wifi card has to have its own antenna in the form of a wire that snaps on to the card that you have to drape as best you can.
Edited by Bombastinator
you could get a pci card that accommodates that card, otherwise, yea unfortunately.
Thanks for the info, i didnt knew that. Unfortunately mine doesnt have the extra slot):
 Share
