720p not supported on VGA?
Mark Kaine
so I've been resurrecting my old (and very glorious) Athlon 64 x2 Windows Vista PC... as far I can tell it has only VGA as Video output (NVIDIA nForce graphics) and when I set it to 720p my TV (FUNAI 720P) says 'not supported' anything lower than 720p works tho, and I know this TV supports 720p for sure (over HDMI at least)
So any ideas how to fix this?
Do I need an adapter?
I will also install a ATI X1950 GT later, maybe I have more options with that?
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
Either the VGA port on your motherboard or the VGA port on your TV doesn't support 720p over VGA.
Do you have another VGA device that you can test with so we can figure out which it is?
elephants
hmm..... its probably hardware end. I can do 1080 over vga fine.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
Specs would be helpful. VGA can definitely do well above 720p.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
Just over 1080p is the most commonly highest supported resolution that most VGA cables can do. (in other words your far from an issue using 720p on the VGA standard)
As another comment suggested your probably coming against a hardware issue my friend.
R U L E  # 1   A b o u t   M e:   I   u s u a l l y   g i v e   D U M B   a d v i c e   a n d   y o u   s h o u l d   n o t   l i s t e n   t o  m e.
I see, unfortunately I don't really, but I have dvi - vga adapter, and I think also dvi - vga cable, or possibly hdmi - dvi... I just checked what I have right now without searching too much :
(the little one is a msi 'comanche' d64 - without vga port apparently!)
the round port is S-video I think? maybe that would work, or the adapter? edit: just checked that's 480p lol, so maybe the vga-dvi adapter, or maybe vga-dvi-hdmi? Otherwise it's either the cable or the TV, or motherboard (though how likely is that?)
well I also have my Asus mx 279H, but it's stashed away, and I'd rather not set it up at the moment - not a lot of space where I have the Athlon PC.
Yeah it's probably the TV, but not sure. 🤔
motherboard is (Asus, probably) M2N68-LA (HP prebuilt)
cpu: AMD Athlon 64 x2
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
42 minutes ago, PlayStation 2 said:
Can your TV accept an output of 1024x768, by any chance?
yeah, it does, but also 1360x768, and 1280x768...
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
I'm suspecting that your TV:
  1. Doesn't like 720p signals being sent through a VGA output, at least concerning that PC. It could be outputting something that it's not expecting for VGA for whatever reason.
  2. Your TV taps out at 1360x768. Most 720p TVs don't have a native resolution of 1280x720. Many of them actually top out at 1360x768 or 1366x768, while some older TVs top out at 1024x768.
If it's not bothersome and 1360x768 happens to work, just use that.
Almost figured, though it's weird if I plug in my PS3 over hdmi it'll say '720p'... but I guess the vga port is less 'optimized' for lack of better word.
And I really would have liked to play at native resolution of the TV - which im now not even sure what it even is.
But for the time being it's fine, I'm just testing stuff, maybe it'll change with a GPU, but looks this TV doesn't even have dvi, so I need to use an adapter. (which I remember I always did, but that was with a monitor.
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
