My RTX 3070 has only 1x 8 pin connector - is that an issue?
Solved by SEAL62,
The manufacturers (even the cheaper ones) know pretty well what they are doing and if your GPU only comes with one 8-pin connector than that is the way it was intended by the manufacturer. So nothing to worry about here.
runningdecoy ·
Posted in Troubleshooting0 -
1
joshp305 ·
Posted in New Builds and Planning1 -
3
4
Inception9269 ·
Posted in PC Gaming0 -
1
2
play_circle_filled
Latest From Linus Tech Tips:
The BRIGHTEST Monitor We've EVER Seen - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
