Lian Li Galahad / NZXT Z73 AIO ?
AzowiX
What you think about this two options?
Have dramatic difference in performance on them?
5 hours ago, narrdarr said:
lian li is better but pump maybe louder
You think the LCD screen is gimmick?
what do you mean?
it's for aesthetics. it doesn't do anything for performance.
personally if you want something that looks good and performs well I'd get the phantek glacier aio.
1 hour ago, narrdarr said:
what do you mean?
LCD screen on the Z73.. you can see some GIFs with tempertature and more..
it your choice if you like it get it
Z73 / ROG Ryuijin 360mm? Both have screen on them.
