Old AM2 mobo, what is SPDIF - OUT, because it doesn't look like it should - also can I connect a LED case fan? :D
Solved by minibois,
2 minutes ago, Mark Kaine said:Seriously I don't understand this port at all, looks like a fan plug? And SPDIF is optical, and even if there's a SPDIF plug that's not optical where do I connect the other end? And since it looks like a fan header, altho just 3 pins, could it be used for a LED case fan?
No, you cannot connect a fan to that header.
This header is for using soundcards, the older kinds sometimes needed this header to support optical audio.
