Search In
  • More options...
Find results that contain...
Find results in...
DNS on edge chromium
Go to solution Solved by LAwLz,
That's weird. Cloudflare still shows up for me.
Try putting in this as the service provider:
Quote
https://chrome.cloudflare-dns.com/dns-query
Before doing an update, I can choose the dns provider that are listed, but now the list is gone, and I dont know how to add the provider manually, i want to use cloudflare dns, does anyone know how to add it ?
Thank you
Quote
Thanks!! it worked, now I can redditting again
yes, reddit is blocked in Indonesia
