Is PCIE 6+2 to ATX 12v 8 pin adapter safe to use.
Solved by Skiiwee29,
You only need a single 8 pin. You will never draw enough load on normal/conventional cooling solutions to need any more than that. Also, its never a good idea to adapt from one power type to another. If you truly want to use both 8 pin EPS, then buy a new PSU that properly supports dual 8 pin EPS.
Redsin ·
Posted in Graphics Cards1 -
BTSHalfLifeAndGmodFan2003 ·
Posted in Graphics Cards12 -
1
2
2
4
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
